RichardTaylor
I need some help, I have a 2003, 2500 4X4 Automatic which occassionally has a up and down idling issue? Here is how it goes. I start the truck and drive around town stopping and starting as normal and then all of the sudden I start the truck and it begins to surge up and down about a hundred RPM's or so it usually stops after a few blocks or so. Then on other occassions it won't start at all it justs cranks. but that has only happened once. It never seems to occur until the engine is fully warmed up and I have been driving around town a while. This problen does not occre all the time, I can go for several days or a couple of weeks with no issues and then all of the sudden it does it again. I have the new in tank fuel pump as mine failed a few years ago, I change the fuel filter with every oil change and I have about 90,000 miles on the Cummins. I am aware of the injector pump and injector failure issues with this year of truck at this age and mileage but I'm not sure of the proper diagnoses for those issues. I also have an EDGE chip installed which I did pull the jumper on, but did not uninstall yet? What do you think?
