what do you have?
i have fire stone ride rites, but am looking for an in cab controller and thinking about on board air (killby interprises)
where did you mount your gauges, electric senders or mechanical, how did you wire it? where are your tanks ad how big?
here is what i am thinking for me...
remove the leaky quick fit tube setup they supply ad switch to copper tube. run the bags in paralel as the fact the goose is always a level side to side load. run them to a set of selanoids, one for fill and one for dump. electricaly controlled. run a T fitting and put a pressure sender on that side.
run a 5 gallon air tank under the bed behind the left rear wheel and a pressure sender on that. have a quick connect on the front and rear bumpers. then run on board air like normal.
switches and gauges would all go to the right of the steering wheel but to the left of the radio on the dash.
any input?
Grant
any input?
Grant
