Geeeeee. . There is one he11 of alot of "your truck is the only one that has ever done that" out there. The 5star retarts at the local Chico, Calif dealer has blamed everything from my bug deflector to the sprayed on bed liner. Mine has been back so many times I couldnt begin to tell you. The problem has finally been so so cured by Les Schwab Tires. hey do all the brake and alignment on my Corvette so I figured, what the he11. No cost I might add. What they did, I couldnt tell you but its a totally differnt truck. Ill bet if you pull your front right tire you will find a spacer. Thats right, a spacer. Thats one of the Dodge boys quick fixes from the FACTORY! All my buddies have them on their trucks. Dodge knows there is a problem and they refuse to admit it, tho... . the new trucks have 4 wheel disc brakes. Gee, that seems to have fixed most of the problems. Mine was so bad that the service manager didnt beleive me so he took it out for a test drive and came back 10 min later white as a sheet! Turns out he almost flipped the truck when he did a panic stop and ended up off the side of the freeway and then over corrected. A total dumb a$$. The guys in the servive dept wished that he would have flipped because it would have gotten rid of the servive manager and MY TRUCK. Dont get me wrong, I love my truck, but... . it took many moons before I could say that. I think it was shortly after Chrysler refused to buy it back and I took it upon myself to have a REAL SHOP look at it! I just wish I could get the full price of the 7/100,000 warranty back. Shooda, coulda, woulda! Im now into the "my driveway waranty station". None of the want-to-be menhanics will ever touch my truck ever again.
98 Quad Cab 4X4 Cummins PAID WAY TOO MUCH$$$$$$$$ Automatic Totally loaded Minus fuel sender plus right brake pull, no extra charge! K&N filter, Line X spray on liner that chips everytime I haul something, WORTHLESS CHRYSLER 7/100,000 WARANTY, First name basis with Enterprise Rent a Car and my local AAA tow truck driver.
[This message has been edited by Phil Johnson (edited 01-03-2001). ]
