Roadmaster - What's the Verdict?
Amsoil Remote Bypass
Single or Dual Steering Stabilizer?
John,
No data with the camper on the truck. The camper is 1800lbs wet and does not even bring the back of the 4x4 level. I had air bags but only to control side to side sway. The bags are now off and I'll try it without them first.
2001 HO 6 speed Regular Cab SLT 4x4 3. 54 anti spin 2500. Used for the daily grind and sneaking away to some secret Baja beaches toting a cabover
I agree with Steve G. I think Mr. Bob`s spring spacing setting at . 080 is real conservative. It set the coil spacing at . 120 today. Much better. It really didn`t improve freeway bounce much, but the truck corners MUCH better and the driveline has a much "tighter" feel will less slop.
There should be no problems with axle wrap/wheel hop in the snow... I`m hoping. #ad
Bill R
94 2500 SLT 4x4 5 Speed, 3. 54 LS, JRE 4" exhaust, Autometer Pyro, Boost & Water temp gauges, Bosch 215 HP injectors, Timing @ 14. 7 º, JRE Stage III #4 plate 270/675, AFC spring kit, Scotty Air, Bully Dog Propane Injection, Roadmaster Active Suspension, Optima Red Tops, Geno`s Exhaust Blanket,Espar Heater (won it!), Synthetic lubes throughout.
Bill, I have to back up in pea gravel near my garage and was getting lots of wheel hop in reverse before the Roadmasters. The Roadmasters eliminated almost all trace of wheel hop . 80 probably gone completly at . 120 #ad
