gutting the muff
I am posting this for KEIMMO
Gutting the muffler is a two man job... mainly for getting things apart and back together. You can separate the exhaust
either at the muffler or the extension pipe just ahead of the muffler. Choose the one that the clamp has dented less.
You should be able to get the muffler and tail pipe off the truck together, making less work and not affecting as many
joints.
There should be a guide welded to the pipe that slips into a notch in the pipe/muffler that slips over it. Use a sharp
chisel and remove as much of the guide as possible. It really helps when you take things apart!
To get the exhaust apart, you need someone on the back turning the tail pipe and pulling while someone else heats the
joint... and you usually need LOTS of heat! Avoid wiggling the pipe back and forth as that flairs the end of the joint and
makes it harder to seal later. Twist and pull!
I pulled mine apart just ahead of the resonator. There was enough room after removing the spare tire to slip everything
out the back. My truck is a 2nd Gen... it might be a little different getting things apart on your truck, but the
principal will be the same.
Do not forget to start the truck and see how it sounds without any exhaust!
If you look the muffler over, you can probably see where there is a baffle plate just a little way from both ends if you
have a round muffler. If you have an oval muffler, all the information will be basically the same, but it is harder to
tell where the baffles are and harder to weld back together because it has two layers of metal... an inner and outer layer.
The rear baffle is farther from the back than the front baffle is from the front. Cut the muffler with a hack saw in
the middle of the center chamber or a little toward the back... about the middle of the muffler. It doesn't matter if your
cut is straight or not... just cut it in two. I don't know how many pass tubes there are in your muffler. They are usually
a press fit inside the muffler and will separate if you wiggle the muffler back and forth after you cut the case in two.
If not, you will have to find a way to cut them too without destroying the case.
Leave a little length on the inlet pipe... not over 6 inches behind the front baffle. Angle cut it with a torch with the
long side toward the case and the short side facing the outlet pipe. A pretty angle doesn't matter or if it isn't the
same side to side. Deburr it well on the inside of the pipe. Cut the outlet pipe about an inch from the rear baffle.
This in not rocket science, so cut it with a torch. Use pliers, hammers, or what ever works to flair the end of the
outlet pipe. You will probably have to heat it to bend it into shape. Do not worry about uneven cuts or burrs... just
make a funnel on the end of the pipe. Flairing the pipe is important! A flaired pipe will flow about 25% more that a
pipe that has just a square cut end!!!
If there is another pass tube, remove it completely. Spot weld the pipes to the baffles if there is any question whether
or not they will hold!
I have no doubt that the front baffle will have several holes in it. Leave them. It makes a silencing chamber to reduce
noise. You can as an option weld a patch over a hole or two if there are lots of big holes. If the rear baffle has holes
in it, likewise, leave them. Again, you can weld a patch over a hole or two if there are lots of big holes. Big flat
washers make great patches! Leave the hole/holes open that best align with the inlet and outlet tubes. Again, it will
make a silencing chamber to kill sound waves. If there are no holes in the rear baffle, like my muffler, cut a couple of
1-1 1/2 inch holes in it. Use the torch... neatness doesn't count. Just get a couple of holes for the sound waves to
enter... they can be round, square, or shaped like the State of Texas... it doesn't matter!
Weld the case back together and reassemble the exhaust. Take out for a test drive and come home with a silly grin. If it
helps your truck as much as mine, you will be impressed.
Have fun! Feel free to write if you have questions or comments.
Steve My truck is an '01. 5. The performance difference is amazing... especially the part throttle responce!
Fuel economy improved about 2 mpg. I tow a heavy travel trailer through the mountains. There is NO drone at any speed,
load, or throttle!!! Overall, my exhaust really isn't any louder than stock. It DOES have a slightly different tone under
certain conditions... but NOT louder. If you have any questions about how to gut your particular muffler, feel free to
contact me with questions or comments.
