crobertson1 - Nice pics on the SM install. Is there enough play in the setup that you did not need an "s" pipe of any type? You just got it to line up from the cat outlet straight shot to the stock tailpipe and then welded on some hangars at the right spots?
Correct. There are no "s" pipes. The muffler shop simply installed it like you said. It seemed pretty straight forward to install it. He left the rear part of the exhaust hanging while he welded it to the cat outlet then connected the rear part and welded it up. Easy as pie. I wish I could've got a picture or two while it was on the lift. It's hard to get a decent picture while it's on the ground.
