Originally posted by WCrawford
I have 40K miles on my 2000 2500 Automatic. I use Rotella T and chane oil and filter every 5-6K miles (I tow a TT). Is there any advantage to going to synthetic lubricant (Amsoil, Mobil 1 etc)? Can't decide if I want to switch. Considering changing synthetic @15K miles and filter @7. 5K. How about synthetic Transmission fluid and rear end lube. Any feed back, opinions? Thanks
Here's a few opinions (sprinkled with a few facts):
1) You're towing, and must care about vehicle life or you wouldn't ask these questions. If you don't have one already, get a pyro. When pulling loads, you'll know if you need to back off the throttle, and you'd be surprized how long you need to idle for turbo cooldown when you've been really working the engine. Save that turbo!
2) You mentioned Mobil 1 as a possible option. Mobil 1 is not rated for heavy duty diesels like ours; you want to look for another product called "Delvac 1", also made by Mobil. Don't be confused; Mobil makes "Delvac 1300" (non-synthetic), Delvac 1 (synthetic for HD diesels), and Mobil 1 (synthetic for gassers and some light diesels).
3) Opinion: I have come to believe that having a good bypass filter is extremely important if you are going to extend the drain intervals. So is doing oil analysis.
4) I think the owners manual recommends a synthetic in the rear end for towing, in a 75W(?)-140 weight. Check and see. For your application, I think you HAVE to use a synthetic to meet the manufacturer's recommendation.
5) With either your Rotella, or synthetic, your engine will outlast the rest of your truck. By the time you balance the costs of synthetic plus analysis, with fewer changes, the costs will be in the same general ballpark, +/- depending on what intervals you select. Your decision should hinge on side issues, like, do you want/need better cold weather starts when no plug in is available? How many miles per month do you typically drive? How easy is it for you to get the oil changed, and how often would you have to do it? Do you sometimes get impatient and shut down without cooling the turbo enough? (the list goes on... )
