Rough ride while towing.
I got my 03 3500 DRW 6spd about three weeks ago. Other than the little (3000 lbs) trailer I tow for work it has not towed any thing. Yesterday (Sat) I towed my car hauler, a little info on the trailer, bumper pull, 20' long, steel beck, 10,400GVW, a slipper spring set up, 7. 50x 16 bias load E trailer tires aired to 65psi with a 75psi max, brakes on both axles, empty weight about 2500lbs. This trailer is made by PJ and is sold as a equipment trailer. I drove about 100 miles empty and the ride was worse than it was with the same trailer behind the 02 2500 6spd I traded in. I just figured it was due to no weight on the trailer. Well when we got the Ford loaded and headed home the ride was worse than empty. The ride was very jerky, The tile of the 55 Ford says the curb weight is 3500lbs so I am guessing the truck is closer to 4000lbs. My normal load on this trailer is about 7500lbs which I have not towed yet with this truck. When I got home I removed the fourth and sixth springs from the top down, in the trailer spring packs. I was informed by the dealer that they were 6000lbs per axle springs, true or not I don't know. I then loaded up a Jeep that weights about 4000lbs or so and went for a drive. It was better but I am still looking to do more since most of the hauls with this trailer are long.
Any Ideas?
I was thinking about a set of Bilstiens for the truck.
Thank you for your help.
Scott
Any Ideas?
Scott
