85,000 miles. Over the last few months I've been seeing a rough running engine with little power after start. It doesn't always do it, but it does repeat. I turn it off and re-start and then all seems normal. Any ideas?
Did you ever find out what the problem was? I had a similar issue that I correlated to the alternator load. The fix appears to have been a ground to the ECU.. though it's a bit of a guess. Here's that thread:
https://www.turbodieselregister.com...t-misfire-during-high-alternator-load.269863/
I was having a similar issue, and think it might have been the ECU ground strap/mount. It is impossible to be sure, but the problem seems to have gone away when I swapped out the ECU and cleaned and re-installed the ECU and it's mounting plate.Still want to figure it out. It doesn't do it often, so I'm going to wait for it to happen again. Thanks!
