Rough Running at Start
G56 drain plug size
How to Obtain DTC Codes
85,000 miles. Over the last few months I've been seeing a rough running engine with little power after start. It doesn't always do it, but it does repeat. I turn it off and re-start and then all seems normal. Any ideas?
Your fuel rail pressure sensor may be your problem. Sometimes the problem will appear before a code is set. Check for codes. Sometimes when the sensor is starting to have a problem, the engine will lope/surge when first started. Later, it will start to run rough and finally it will reach a point where it won’t start at all.
