I have a 94 2WD auto that has more than 365K miles and no mods. I've had it about 2 years for a daily driver and had no problems, but yesterday after work it took a couple more turns of the starter to fire it off then it imeadiatly started runing rough. RPM or gear dosn't make a difference and there is almost no power. I just got through running a 500 mile road trip two days earlier and got 23. 5 mpg and also did not have any issues that morning on the way to work.
Changing the fuel filter did not make any difference and I still have to replace the fuel lines and strainer. It seems odd that there is a sudden degidation of performance from morning to afternoon and seems to be permanant.
I loosend the injector lines at the pump one at atime and 1/6 cause the engine to almost stall while 2/3/4 caused the engine to smooth out.
If that's not it, I suspect maybe the timing slipped when shuting down the engine yesterday morning. Would a bad injector cause missing/rough running?
