Here's the issue. I've had an intermittent, now constant issue under load. It may be a "miss", feels like you're driving on washboards when it happens. It's noticeable under load 3&4 gear uphill pulls, anytime with trailer. Runs fine at idle and cruise.
Here's my rig: '99 2500 w/205k. Free flow intake and exhaust, rv injectors, Tst 10 level box with remote and system on/off switch. Remanufactured vp44, other mods to drivetrain.
Here's what I've done so far: no thrown codes and nothing a basic scanner picks up, had a loose ground/negative wire. Fixed, problems went away. Now it's back and worse. Checked wires and all "splices/taps" for fueling box. Cleaned and reconnected, no change. Replaced MAP, no change (had spares).
Have gauges in cab for ex temp, fuel press, and boost press and all in range of normal. Problem is very bad with fueling box on, very slight with off.
Any thoughts?
Any thoughts?
