RTV Silicone sealer
Apollo Spacecraft questions and facts
3126 b cat
ACoyle
Super Moderator
Is there anything that it does "not" stick to?
I need an irregular shaped gasket and thought that 2 layers of something that it dosen't stick to separated by washers would make a pliable material to cut a gasket from that woul not leak.
Thank You
AC
Good question. I know if the surface to be sealed isn't completely clean on oil, it won't stick. Outside of that, I have no clue.
I want a couplw 24" Grovers on top of the cab, just terrible bad. I don' know if the inspection dudes will stop me yet. I don"t want the leak to go with it. Was just thiinking that RTV gaskets would do the job nicely.
If you put a light coat of Vaseline on the mounting surface and on the item to be mounted, then place your RTV and make up the assembly, then you will have made a "formed-in-place" gasket.
