HEMI®Dart
Hi Guys,
I did't have the noise until I changed the front brake pads yesterday. Installed new slider bushings and lubed them well. Rotors were not bad so I did't have them turned.
A right hand turn will make a low pitched grumbling/rubbing noise.
I jacked up the front end and could't find anything loose. Front axle U-joints are tight. All the steering linkage & ball joints are tight. Calipers are torqued to 38 ft lbs. I cant duplicate the noise in the driveway with wheel turned to the right on the jack. I don't get any bearing noise spinning the wheels.
Could the new pads be contacting the lip on the rotor that is not used (rusty edge) around a corner? Something would have to flex?
