EricBu12 said:Get the 19. 5" "F" rated tires and rims. .
I have the Ricksons Forged Aluminum Rims and Michelin 245 70 R 19. 5" ... Rated at 4080# @ 95 psi...
Now The only time I air up to that, is when I tow my heavy 5th... When solo, I air down to 60 front and 50 rear. This makes a firm but not bad ride. ... Yes there is a difference between the 16 and the 19. 5... Firm and slightly bumpy... . but not as bad as 22. 5 Truck tires...
I torque the rims to about 120 - 140 #... . about normal... .
EricBu12 said:Anytime you get larger tires, braking will suffer... . It don't matter what brakes or tires you have...
I have a Jacobs brake and even solo, I use it to slow down first and gears and then brakes... but yeah, A little mre pressure is needed... but you will stop better with disks than drums by a long shot... .
