Hey guys,
For those of you with running board lights, did you mount them directly onto the sheet metal lip on the bottom of the rocker, or did you make a strip of steel to mount them into, then mount that to the lip?
I found a 12 light/wire/connector kit at Pep Boys for $25 and thought about installing this since it is cheap, and if it grows on me I can replace them with LEDs later, if not its only $25 down the hole, rather than buying LEDs which are $10/each for the same size as the ones in the kit.
And did you wire in a relay or just tap into the running light wire?
Thanks!
Thanks!
