My truck came with DEEZEEs from front wheelwell to rear wheel well, I don't go 4Wheeling but I can tell that if you get off road very much they would get torn up, they really widen the lower portion of the truck.
I'm contemplating larger tires and wheels and it looks like I will have to modify the front end of the running boards or the tires will hit(even if I only go to 265's)I'm leaning towards 285's or even 305's but I need to get skyjackers 2"lift for the front first I think.
Hope this info helps.
Caleb
1993 LE W250 4x4 CC,Auto,3. 5's,LS. . Diamondplate,PowerWagon injectors,K&N,Egt,Boost,trans temp VDO Vision series, BD 3 1/2" Exhaust, 16cm housing,Mag Hytec Diff+ Trans pans,Transgo TFOD shift kit,Roadmaster Active Suspension.
Caleb Reese (per forum guidelines)
