Running Flux 2 Injectors before getting twins
Edge Juice instead of Smarty ?'s
Has anyone seen/tried these twins??? Cheap..
Just checking to see if there are any opinions on running the Flux 2 injectors with out the twins. I am hoping to be able to afford the turbos this winter, but I can only do one upgrade at a time. Since, I have at least on bad injector I plan on upgrading them first. I was going to go with a set of II injectors, but they do not have any cores to make me some, so it looks like I am going ot have to pull mine and send them out.
I just want to make sure I am not going to hurt anything when towing. I haul12-13k once a month and a 8k regularly. I figure I will have to watch the egt's and turn down the TST... Is that going to be enough???
TIA,
Aaron
Towing w/Flux
TIA,
Aaron
I have 2. 5s,. . but I have twins. It's a beautiful thing to tow with these. I am by coincidence towing almost exactly what you are re: lbs,... but I tow much more often. Don has quick turn over when he knows your situation so I'd say go Flux.
