2nd Gen Non-Engine/Transmission Rusted out Exhaust
2nd Gen Non-Engine/Transmission interior ideas needed
Engine/Transmission (1994 - 1998) idle speed and adjustment
I have a '99 CTD 4X4 SHORT BED , my problem is the exhaust has extremely bad rust spots ( the tail end pipe from the muffler just fell off) through out the system, two questions
1) is it normal to have an exhaust rust this bad in four years ?
2) does the DC 7yr/70000 miles warranty cover this problem
Gerard.
I had the same problem on mine. One of the previous owners had re-welded the same spot before I bought it in 11/01. It wasn't worth it to try and weld it again, so it was replaced.
As far as warranty, does your ownwers manual say anything about it in there? Sometimes the emissions/exhaust are a little different that way.
Stock Exhaust
As you can see below, I also have a 99. My stock exhaust rusted out approximately 3 months ago. Evidently the longevity seems about average.
I called Rip Rook and installed his system. Very happy with the choice!
I'd be willing to bet DC see's the rust as a normal wear and tear item like a drive belt, and would not cover it. Mine is rusting, in the same areas described above. Just replace it with a new one, if you plan on keeping the truck for an extended period a stainless system might be worth looking into, spendy but it lasts a bit longer.
Used OEM Muffler
I have a used muffler from a 1994 for sale. I took it of at 10000 miles and put a straight pipe on it. Will sell cheap. PM me if interested.
It appears most of the complaints are on newer 2nd gen trucks... the 94-early 98 exhausts were different... . at least the exit pipe was. My 96 has no rust problems, neither does my brothers 96 nor my parents 98. I've actually been impressed with how well the exhaust looks on ours after so much wear(230k miles on mine, lots of off-road).
then again it may be because we live in the south and are never exposed to road salt?
Just for grins and giggles here, how many of these rusted, busted exhaust systems are located in states that salt the roads:confused: A survey might produce some interesting results. :)
While you're under there checking the exhaust for rust, you might also want to look around for other important things that might be rusting. Like the brake line that's tucked into the frame, (hidden behind the fuel tank), on the drivers side. Mine rusted through and blew when I hit the brakes coming up on a stop light a couple weeks ago. Glad I wasn't loaded, and there wasn't anything in front of me. It's fixed now, line fell apart when I was taking it off. I think everything rusts worse on the East coast than it does in Alaska.
Jim
Gerard,
My 97 tailpipe rusted out first at the hangar bracket and then fell off at the muffler exit @approx. 60,000 miles. I see that we are neighbors. I had my muffler and tailpipe replaced with NAPA parts by my Branchville mechanic for a little over $300.
I also have the 7 yr warranty - this is a wear item and was not covered.
Ken
Originally posted by KEnhoffer
Gerard,
Ken
I thought as much (kind of hoping i would not have to shell out any money for repairs :{ )
would you mind giving me the name of your mechanic , it would be great to be able to go to someone close by and knowing that they have done this type of repair .
thanks
Gerard.
There is a guy on ebay selling the 4" Magnaflow stainless system for cheap. I think that is one heck of a deal... ... now just wish my damn exhaust would hurry up and rust out:D
Here is the link if you want it.
I think alot of the problems are related to were you live. Guys in Texas, New Mexico, ect will not have alot of problems for the first 4-5 years. Where I live in the middle of the SALT belt, the exhaust system will live a much shorter life. It is no secret that all the major automobile compannies use products in there new vehicles that are less then on par with replacement pieces. The tires are all special runs that do not hold up as "normal" tires would, shocks,batteries and exhaust systems are all guilty of being on the "low" end of the quality spectrum. What I don't get, is that when these systems do fail, why would anyone replace it (exhaust system) with another "steel" system?? Why not go with a stainless steel product and not have to worry about that part of the truck again??
white winter coat, not snow dust?
You mean all these years I've thought that white winter coating on my truck was snow dust it was really salt?
oh, I guess that explains why the exhaust system fell off and why the underside of the truck is starting to have a rust color to it... that same color seen under the carpet that was found wet for some unknown amount of time.
Does that also explain why wiring keeps being found to be green rather than copper color? Those aftermarket backup lights died from that problem...
damn, I was much happier thinking that it was just snow dust... .
Maybe someone will come up with a full body linex or other coating for us rust belt folks that is cost effective.
And I bet BPINE's truck is still showroom clean on the left coast...
LOL :D
