Engine/Transmission (1994 - 1998) safe to slide tst #10 all the way forward?
2nd Gen Non-Engine/Transmission Brake Light & ABS Light
Engine/Transmission (1998.5 - 2002) Trailer Life - new BHAF
you can see my mods in my sig at the bottom. Is it safe to slide it all the way forward? will i pick any power up? i just got a con 13inch OFE installed and am looking for a little more go.
you can, but keep a CLOSE eye on your EGT's!! Mine are outrageous when I punch mine (See sig) empty, and towing. . I tow frequently, and have to constantly keep an eye on my gauges. Do it, but at your own risk. . Just my $. 02 worth. .
-Chris-
-Chris-
Chris take another close look at his sig.
*16cm housing
*3K GSK
*Banks Exhaust (guessing 4")
*Mega Cannon
don't see any injectors so I'm guessing originals..... I think that he will see slightly higher EGT's... ... . they will climb quicker... ... but it won't be that bad..... try it and see Clayton!Oo.
Still have to watch EGTS...
I am running with the plate 3/4's forward. While doing some recent towing (pulling double stock trailers) I found EGTs to be aceptable when towing 70 mph with the tiny hills we have in ND. Never used more then 2/3s throttle, 28 llbs boost and 1200 EGTs max. I did WOT on a couple of hills and yes EGTS when right past 1300.
A #10 in a 215hp pump takes the stock turbo to the limit. Even with a 16cm housing.
But then I am only 2/3s foward!
jjw
ND
Re: Still have to watch EGTS...
jjw
ND
JJW I did neglect to look at it from a towing perspective. :eek:
But I know I ran with mine full forward for about 2 weeks, and I have marine 300's as well. My EGT's did climb A LOT quicker, and I could be @ 1300* or PAST before I knew it..... but only have a straightpipe and Scotty II to his 4" exhaust and 16cm housing.
Towing YES he woud definately have to watch it as the EGT's would climb quicker and stay there... . he is better suited to EGT's than most people would be though.
