Safe weight and height--hauling in the bed of my truck
trailer to tow east
5ver Suspension Lift HELP
Looking to take 2400 lbs about 500 miles max payload is about 3400lbs. Don't want to take the trailer if i don't have to, but want to be safe as well.
I have 2001 short bed 2500.
Hauling 2 crates that are 6L x 4W x 3H. I will need to stack them if I put them in my bed. the 1300lb on the bottom the 900lb on top.
This will put some of the weight pretty high as I will need to stack them. I tow a lot of trailers and 5th wheels, but have not yet loaded the bed much.
any suggestions...
I have had some huge things in the bed of my 01 and that is getting a bit top heavy especially a short bed I think you will have a uncomforable trip if you do take it on though make sure to use some very overated straos to the bed tie downs as well as the 2 crates together as if you get any momentum built up you will loose the whole thing...
thanks for the advice, I don't think it would be worth it to save 1 hour and $50 worth of gas on a 1000 mile trip.
So I can learn... . what would be a safer limit... . just the height?
Ya, if it was a single crated item sitting on the bed it wouldn't be so bad. But you'd have a seperate 900# crate at least three feet above the bed. If you had to stop or swerve suddenly and the upper crate rolled or shifted, it could cause loss of control.
