If you know how to properly drive a manual transmission then its not difficult to have a clutch last forever. I changed my OEM clutch with 110k miles on it only because I needed a little more holding strength due to the power increase and trailer weight. Surprising to me, with 110k miles on the truck the clutch still looked new. I keep it in my shop too just because its hard to get rid of something in perfect condition.
The two main variables aside from clutch wear is the pilot and throwout bearings. You can lessen the stress on a pilot bearing by NOT holding the clutch pedal at stop lights or for any period longer than it takes to shift. The small pilot bearing cant take the constant abuse people unknowingly subject it to as they hold the clutch pedal down for long periods of time.
But the throwout bearing is a different story. The older cable operated clutches pull the throwout bearing back off the pressure plate fingers via spring pressure. But hydraulic clutches dont do that. Rather the throwout bearing ALWAYS runs in contact with the pressure plate. Yes, its not under immense pressure as you drive along but nonetheless its always spinning at engine rpm. Therefore its important to have a quality throwout bearing.
I installed my Southbend clutch about 2 years ago. After only 5000 miles on it I noticed the clutch getting sticky and chattering a little upon engagement. Turns out the throwout bearing was catching as it moved along the input propeller shaft, and it was spinning rough which transmitted up to the clutch pedal. All of this was causing poor engagement characteristics.
So I replaced the SB throwout bearing with the ONLY American made throwout bearing made, SKF. Found at NAPA for about $120, its obviously built better than the OEM replica throwout bearing which came in the SB kit. After installing the SKF throwout bearing, the clutch pedal has never been so smooth and engagement is just as nice.
