Some folks may think pulling the transmission (NV4500) is no biggy, but doing it on the driveway in the snow is not as easy as some would portray. Anyway some of the key things I wanted to point out for future searchs are listed as follows:
1. transmission/frame support is very difficult to remove and install without a frame spreader. I found it easiest to romove it and instatall in from the rear. I supported the transfere cast and transmission with a large tie down strap wraped around the frame rails and then routed under the transfere case tail housing.
2. The book says to remove the transfere case then remove the transmission. I removed both at the same time. They are heavy. I unbolted the transmission at the bell housing. droping the transmission is tricky and realy requiers a transmission jack. However I spent 3 days bulding a transmission support attached to an ATV jack. The transmission needs to tilt about 30 degrees downward to remove it from the bell housing. The clearance for the shift tower are nonexistant. So, as you pull the transmission back you have to tilt it as much as possible to get the shift tower to clear the opening of the floor board. I actually bent the floor board sheet metal while removing it. I did this by myself and used pulleys and ratcheting tie downs to pull an manuver the transmission out of the way. This was not an easy task to perform alone. Reinstalling it is twice as difficult as removing it. Getting it perfectly aligned by tilting the engine with a jack while manuvering and tilting the transmission is very hard to do on the ground in the snow with out any help. It took me two full days to get it stabbed (about 14 hours of trying). Maybe having a transmission jack would have helped, but my driveway surface is rough, so it made it difficult to roll the jack in small increments to get everything lined up. I actually said a bad word or two while doing this. I noticed my neigbors kept their kids inside while I had words with the transmission.
3. Installing the new SBC clutch was straght forward, but take extreme care to make sure the pressure plate and clutch splines are perefectly centered or stabbin the transmission will be impossible.
4. And finally, dont do this alone unles you have the right tools, or have the ability to make the right tools, and have lots ot time or patience. This is the third time I have done this transmission and do not plan on doing it again. I think it is worth the $300 most shops would charge to do the job. I know a very good and reliable private shop with reasonable rates in Brighton, Colorado. If anyone is interested PM me and I will tell you who and where.
The installed clutch works fantastically smoth and seems to be holding the horspower. The one I installed is the 350-450 hp con ofe 13".
By the way, I have a good used stock pressure plate available if any one needs one. It needs to be turned. PM me if interested.
Here are some photos.
