JGheen said:590??? What happened to the 700 you had? Or was that flywheel power? I thought you had somewhere around 700+hp and 1400+ torque as when I talked to you last year, you mentioned the dyno you ran on could not get an accurate torque measurement past 1400ft. lbs. :-laf
Joe
Not enough load on the dyno.
Also, since Scott dynoed, I believe his truck is running WAY better. It sounds much better than it did earlier in the season.
