Hey all,
My truck came with a Smarty Programmer and an Edge Power Programmer both installed/functioning. I got some work done by my local Diesel guru on my truck and he was very concerned about the Edge and persuaded me to remove it from the truck..He said he's seen extreme carnage with the edge as it has no brain to adjust parameters and basically tunes the truck and keeps it that way. He said I would likely rip my (built) transmission to shreds. Aside from losing my turbo timer functionality, the truck seems to run the same.
Curious as to your thoughts on doing that and the Power Edge in general. This is a very old model that was installed likely just after the truck was purchased in 2001. My mechanic has owned a TON of the 5.9L so I am under the impression he does know what he's talking about. I can try to get a model number off it later if wanted
Thanks in advance
Thanks in advance
