I installed an Isspro EGT (Pre turbo) earlier this week, and it seemed to function correctly for a few days. I would get into the throttle, the EGT would climb. Get into the throttle hard, and the EGT would climb quickly.
However, I have noticed the following behavior over the last 2 days: When I get into the throttle, and the boost gets around 6 PSI, the EGT needle plummets to about 100 degrees!!!??? What the heck? It stays there through about 12 PSI then starts climbing again. If I get the boost up to 10 PSI, then lift off the throttle quickly, the EGT needle drops quickly, and then needle climbs rapidly to 600 degrees or so. What the heck is wrong with this thing, as I doubt this is normal operation.
I was very careful to hook up the wires to the appropriate terminal on the back of the gauge, so I don't I have it hooked up backwards. The wire from the EGT to the gauge does run along a wire loom for awhile. Could electronic interference cause this type of needle movement? Do I have a defective gauge? Thermocouple? HELP!
Scott Collins
'98 Ram 2500 4x4 12 Valve Cummins. Slightly BOMBed!
Renton, WA
[This message has been edited by Scollins (edited 02-02-2001). ]
Scott Collins
Renton, WA
