First leak in 85K! Noticed leak, got under engine and saw evidence of a leak between the power steering pump and the vacum pump. I called local dodge boys who said if it is the pwr steering pump it will cost $380, if it is the vacuum pump it will be $2840!!!, and neither one would be covered. Called Cummins who said it is common for the seal between the two to go out and there is a $8 seal kit and even mentioned a local dealer that does "a lot of them" under warranty!
Has anyone had this problem, is it as simple as a gasket kit and is it covered under warranty?
P. S. Vacuum pump is working and so is the power steering pump!
OH BY THE WAY: Cummins wanted $1200 for the Vacuum pump! Thanks Dodge!!!!!!!!!!!!
