klenger said:I don't have the t-pane windows, but wish I did. I don't know if they were available in 2001. Also consider 16" wheels.
TowPro said:I don't understand, all of the above are companies that make a couple lines of RV's. Some make junk, some make Good RV's. I sure hate to see someone place the glendale name next to fleetwood like that. No comparison
Trophy1 said:Griz
We are going to follow your footsteps to Alaska this July with a Everest by Keystone, It is a great fifth with lot of room we have 343L and LOVE IT. IT is one model down from Keystones Montana and has almost all the amenities of the Montana with out the sticker shock. We paid a little over 29,500. 00 out the door after much dickering with washer dryer and a bunch of other extra's. It has 3 slides 14,000 gross and 2,000 pin weight. PM me if you are interested.
I have also heard that there is are better units by Heartland, BIGHORN< for a few more list dollars than the Everest list. You can easily get a 30% discount off list by dickering some on most RV's.
Good luck on your quest.![]()
K5IP said:I like the Artic Fox also. If you like a good solid camper without all the fluff, you might also look at Nash. It has the same basic construction as Artic fox, but at less cost.
Mine is a 21. 5R. Good and solid. Light weight and great for boondocking. It seems to hold together well no mater how rough the terrain.
Rog
klenger said:I don't know if this is still the case, but when I bought my fox, the Nash line did not have the four-season insulation package or the enclosed heated tanks. Personally, I would stick to the Arctic Fox line and not consider the Nash.
RNelson said:I bought my first 5th wheel a little over 3 years ago. I did extensive research and found the information available from www.rv.org to be very valuable. They are like a consumer reports for RVs. They rate several key areas, towability, reliability, quality. Only one manufacturer rated 5 stars and that was New Horizons (a factory direct company in Kansas).
If I recall, the Nash/Artic Fox product line rated pretty good. Keystone and Fleetwood products were poor.
I didn't want to buy a new one right off the bat, so I searched for used ones. Could not find any New Horizons (seems owners hold onto these). I looked at a couple of Artic Foxes, but ended up finding a NuWa Hitchhiker II, which rated four stars. We've had it now for 3 years. It's a '99 model. Only problems we've experienced are a broken faucet handle and a water pump. The window shades are not the greatest, but everything else has lived up to expectations.
