Is this a quad cab, club cab or regular cab? I've got an idea if its a 24V quad cab... SCTM/ACM fault... there is an easy test for this problem. Otherwise if your belt retractors are B-post mounted its probably just the sensor that "knows" when you reel out the belt. It could be malfunctioning and not sensing you putting the belt on. You do put it on... right?
