After seeing several posts about the difficulty of hub removal and the high costs of doing so , A TDR member sent me a PM on how to remove and reinstall the hubs and bearings. Even with his help ,I hit a snag on the rear-most portion of the job. The good news was that there was no immediate need to remove the bearing on a one year old truck and I had time to think about it before proceeding. I came up with a shadetree solution that involves the making of a simple tool that could be made by anyone with a drill press . It eliminates the ''heat and beat '' method of removal.
My problem is , I need to know how the front end bearing assembly varies on the second generation Rams. Mine consists of wheel spacer, outer bearing race and bearing, seperate rotor, inner race and bearing. It is the inner race and bearing that proves to be the toughest to remove . This tool deals with the inner assembly [that is attached to the truck with the four 12 point metric bolts from the rear]
If someone could point me to some links that show the differences or similarities in these trucks and how the hubs come apart, then I could post how to make the tool and know if it will work for some/most/all of the second gen trucks. BTW mine is a 4x4 3500 2002
Thanks in advance Daveshoe
