I take back what I said in my previous post...
In doing some research to answer your second question about swapping modules, I discovered that you CAN disable the vehicle security system using a Chrysler DRBIII scan tool. Here are the various functions found under the Body Control Module -> Miscellaneous BCM menu:
• Reset Customer Preferences
• Reset Module
• Reset Learned Features
• Headlamp Delay
• DRL Enable (DRL = Daytime Running Lamps)
• Enable VTSS (VTSS = Vehicle Theft Security System)
• Change Country Code
• Program RKE (RKE = Remote Keyless Entry)
• Double Door Unlock
• Rolling Door Locks
• Auto Door Unlock
• Optical Horn Chirp
• Headlamp Delay Time
• Key Fob Test
• Initialize Learn Features
• Initialize VIN
• Headlamps on W/Wipers
• Fuel Gauge Update
Unless you know someone with a DRBIII you can borrow, any Chrysler dealer service department should be able to help you alter the programing.
Regards,
John L.
