Sarge said:Thanks, I just taked to Paul, and Clock doc is right. The O ring is deleted. I just put it in and went for a very short run to the store. It does feel like the responsiveness has improved. But tomorrow will be the real test, when I pull out on the first leg of my vac, since the wife has put almost everything she owns in the rig...
nickleinonen said:i was interested in getting the sensor [or buying a new sensor and modifying it myself] but it is/was much cheaper to "clock" the tone wheel on the crankshaft... 30lbs + 60° is hard to get under there especially when you start to rotate the engine a bit...
and when i ever need to change a belt, the tensioner is so much easier to back off from under the truck than from up top. .
fj40dave said:Are you sayin ya loosened the notched wheel that the sensor picks up the signal from and rotated it 60 degrees?
