Alan Reagan
Don't wait on your belt to wear and break before you replace it on the 3rd generation trucks.
I was due to replace mine, picked one up and three hours later, finally got it on the truck. I'm just glad it wasn't cold and raining.
First, getting the 1/2 inch drive into the tensioner is a lot of fun. From the bottom, it is between the fan and block and you can't see the drive hole.
Then getting the old belt off of the tensioner is almost as much fun. There is a space between the pulley and block that is just the width of the the belt thickness. Make sure you get it on correctly or you get to do it twice (don't ask me how I know).
Then, you will need a thin pull bar to finally get the tensioner to release enough to get the belt under the water pump. The fan shroud and fan precluded the use of my normal pipe pull bar. You need two people to do the final install. One under the truck doing the tension relief and one topside to slip the belt under the water pump pulley.
Since the weather is rather chilly, the belt was stiff and I played the devil getting it to stay in place on the pulleys until the final placement on the water pump pulley.
Do this as preventive maintenance. You don't want to try it on the side of the road.
I'll tell the story of how I decided to change my U-joints during my next installment.
