Thanks for the answer, Im in Seattle and its at Cummins Northwest. They say they have gone thru their diagnosis tree and are down to the Pump. I have had the transfer pump replaced in Yakima 2 weeks ago, because it was cutting out on a hill pulling a trailor. When I got back I pulled the tank to check the screen - OK - but discovered when bleed the system that the water fuel separator push handle leaked when the bleed nut was open. So here I am I spent 550 already for them to the checks in the manuel but I wonder If the return fuel check valve in the transfer pump could be bad
