Shift Lever Extensions
whistleman's fuse blocks
GPS Navagation
Holeshot -
TDR member Bob V can hook you up with the needed accessories so that your EF shifter can control just about anything you want. I am going to have E brake and reverse lights controlled from the shifter.
jason
Matt, yeah newman sells them, I called them in my quest, there minimum order is 50 pieces. You'll have to go to a nut bolt distributor, or try Napa or other parts store they might be able to get one or two for ya. I went to Fastenal, they had a $10 minimum so I bought 3 pieces @ <$3. I ordered two coarse and one fine thread. Fine is no good. Already gave away the extra I had, or I'd send ya one. Also seen where some called them recoil threads or something. I imagine you could rig it up to work electrical. If no big truck yard in your area, Russ Fisher truck parts here in TH, run a search if you want there website, might have 800 #on it, here's the local # 812-877-2535. I think they will ship, if not let me know I dont mind being the middle man. Bill
Jason/Bill - I emailed Bob V... may as well give some business to a TDR member.
Thank you for your input... as always, the TDR has proved to be a VAST source of information.
Matt
