Shifter mounted o/d switch?
1st gen KDP tab & gear housing bolts
injection pump timing
I would like some info on this shifter mounted o/d switch. Like which shifter to get and how to wire it in. It seems to me to be an added coolness thingy.
I don't want to condemed to have to reach ALL the way to the dash to push that darn switch.
I mean, really, if Bob and Mark have one, I gotta have one too.
Any info would be helpful.
thanks
Dave
Dave
I was going to send you a copy of the instructions and a picture of the OEM plug behind the OD switch. But I guess there is no way to attach something with a TDR email. I installed mine in May of 2001. I also put a light in the lower right hand corner of my 3 guage dash pod, which comes on when the OD is off. Mine is setup where you still have the OEM setup, plus the gear shift lever, nothing was disconnected.
Rodney
Rodney - If you don't mind, would you email the info to me at -- email address removed -- - the OD switch is on the list of projects.
page 39 of issue 37 of the Turbo Diesel Register has the hookup, part number is 04690522AB, great minds must think alike, I am planning on ordering my lever tommorrow... .
Dave,
I did this one right after I saw the article. It's so much better than reaching down all the time. While I was at it, I switched the dash o/d switch over to the right, and the cargo light switch to the left. I can't see the o/d off light much better, but a little bit.
Dan
It has been sent. You should have a 2 part instructions and two pic's of my guages, with the OD light in the lower right hand corner.
Rodney
