After I had the input shaft replaced and the FS mainshaft installed I changed the filter kit and put in 6 quarts of Amsoil Series 2000 75W-90 and the thing is shifting great. Now before I go off half-cocked, and give the lube all of the credit, I'd like to say that I've changed my shifting habits slightly, especially from 2nd to 3rd. I've never understood shifting and matching engine speed with a synchronized transmission. When towing I try to rev the engine higher before shifting, for the obvious reasons and some of this habit rolled over into unloaded driving. If I shift between 2125 and 2375 going from 2nd to 3rd, the binding or hard shift out of second generally does not occur. Now, I could still have a shift fork problem(which the dealer said I did) but its not that bad to spend the 600 bucks for a shift box. The guy that "re-built" my transmission said it was exceptionally clean and showed a remarkable lack of wear relative to mileage. He also told me that if there would have been problems with the synchros or bearings they would have been replaced. I'm wondering if maybe I was causing some of my hard shifting problems due to the fact that I never had driven a vehicle with a high performance clutch. I never had hard shifting whatsoever with the stock clutch. It all started with the South Bend. It's shifting as well now as it ever has, and I may have been the culprit when it was not shifting properly. All opinions are most definitely welcome.
As for the lube, I would say that the Amsoil Series 2000 75W-90 gear lube is not damaging to the synchronizers the way many an oil war in the past has refuted or implied. I've towed with transmission temps over 220 degrees with that stuff in there and my transmission was in great shape internally.
