I have a 99 dodge 3500 dually with an automatic trans OD reads 86400.
Had it in for front and rear break work. Front rotors cut ad break replaced, rear adjusted. Now when starting up and the trans first shift thru 1st the RPMs go to 2300 and hold for a bit then shifts in to 2nd. The truck use to shift at 1800 - 2000 smoothly.
Any thoughts of why after the repairs the shifting range change so much? Could they Knock a sensor loss.
The truck will be going back on their dime. :-{}
