Shocking anti-theft system
Aftermarket Speakers
BFG or Dunlop?
Found this on the net,
AutoTaser ($160 after rebate). It's powered by three 9-volt batteries and 8-10 hour daily usage will last about 6 weeks.
If the AUTO TASER’s ultra sensitive vibration detectors sense an intruder, a screeching 120 to 130 decibel alarm is sounded as a warning before aggressive countermeasures are initiated. Five seconds later, a field of electrons completely surrounds the unit. Any attempt to touch the AUTO TASER zaps the thief with an unforgettable, yet non-lethal 5,900 milliwatt (50,000 volt) electron pulse. "
http://www.autotaser.com/Products/AUTOTSR.htm
I have seen those before in a magazine, they showed how to beat it too, the thief wears line handler gloves (available from electrical supply houses or a friend who works for a utility company). Great idea though.
My friend actually took apart and mounted 2 stun guns INSIDE the driver and passenger seat with the probes against the inside of the leather seat. The drivers seat would activate when the alarm went off. For the passenger side he mounted a switch on his side so when his girlfriend was complaining about something he blasted her with it. I got hit too when i complained about his driving. Suprisingly, he does not have alot of friends anymore... Go figure.
(snip)
Something's not right. 250 mw can kill. Secondly, 50,000 volts times 5,900 mw is 295,000 watts. That's enough to power about a hundred homes.
James
1990 Ford 1/2 ton shortbed 4x4, 351, 4. 10 LSD
[This message has been edited by Ethdee (edited 05-18-2001). ]
I don't know how 5900 milliwatts becomes 295,000 watts. I know of no formula that would work for that. Using the formula P=IE (Power=Current x Voltage) you can convert to I=P/E to find current. 5. 9 watts/50,000 volts= . 1 milliamps which is not enough to kill anything.
Phil
'99 D3500, auto. ,2WD,3. 55 LSD, all options, Banks Power Pack w/K&N filter,DTT TC & VB, Mag-Hytec pan, '99 40ft. Alfa Gold Triple-slide 5'er
"Ignore your rights and they'll go away. "
Sticker on the dash panel of my '76 H-D
"Is there life after death... Touch this bike and find out"
The shock a thief needs to worry about is when I catch him and he hears the 3" magnum shell slam into the chamber of my 12Ga.
I have not one but two anti-theft devices,land sharks 85lbs each and these girls don't like anybody messing with THEIR truck!
My truck 01. 5 2500 4x4 SB,quadcab,auto,3. 54LSD,tow/camper pkg,HD241,bronze; Dad's truck,96,3500,ext cab,4x4,5speed,4. 10LSD,white
Actually, any amount of current over 10 milliamps (0. 01 amp) is capable of producing painful to severe shock. Currents between 100 and 200 mA (0. 1 to 0. 2 amp) are considered lethal. Strangely enough, currents above 200 milliamps (0. 2 amp) usually don't cause death but will produce severe burns and unconsciousness. This also assumes the current to flow through the heart.
David Dressler
2001 Driftwood 3500 Quad Cab 4x4, 155 inch WB, HO Cummins ETH/DEE, SLT+, 3. 54 LSD, Camper Special, Trailer Tow, Heated Leather, Sliding Window, Jacob's E-Brake, Rhino Liner, VDO Vision (pyro, boost, engine + diff. temp. ), Autometer Ultra-Lite (electric fuel pressure, vacuum), Weather Guard Diamond Plate Saddle Box, Tork Lift camper tie-downs, Mag-Hytec, Mopar Tow Hooks, SmittyBilt Outland Sport Bumper Gaurd, 2-LO kit, AND functional Halo light!
Bigfoot 3000 10. 11 Slide-in Camper. "Do it in a Dually"
Oops. Thanks, Ramboy, I had a brain fart on that one. Not only did I look at milliwatts and think milliamps, I TYPED milliwatts and STILL thought milliamps.
That was a bozo mistake. I will never again post that early in the morning.
James
When I tried to order one several months ago, the company said they were back ordered for several months due to a large international order. They would email me when available in the U. S. again. Never heard from them yet, they probably just forgot about a single order. These things are illegal in certain states, (like Hawaii), but they would ship it here anyway.
