Shocks & Guages
Differential Skid plate(s)...
Do you have to Calibrate the SPA's?
I am in the market for Rancho 9000 shocks (any sales going on?) and Guages, EGT, Boost, Auto. Trans. Temp. Question: Best mfg. , Best price.
Thank You - John
2001, 2500-4x4-Auto-4:10
Cant help you with Shocks, as for gauges, there is a TON of poste regading them. I have and recomend Autometer. They are the most accurate and Reliable (That is fact, not opinion) When you order there EGT gauge make sure you go with the Competition Thermocouple to get the most rapid readings. Also, call them for exact P/N's and the checpest place i have found to buy them is www.summitracing.com Summit wont list alot of the part numbers you need, but they have them, you have to call to order.
Also, despite what you read, all of there series of boost gauges are available in 0-35psi and most are also available in 0-60psi.
Genos gargae prints in there latest catalog that ONLY the Ultra-Lite series boost gauges are available in 0-35psi, which is totally false (I have a 0-35PSI SPORT COMP in my truck). I called Genos and asked why they say that and he said "we were unaware they were available in other series" and said we wont carry other series because "we have too many different types of gauges already.
So, my point is, dont listen to everything a distributor tells you.
Good luck
John - I Just installed 4 9000's on my truck, got them from hotrod-offroad.com they were 55. 99 ea + shipping 18. 00) Hope this helps
2001 Patriot Blue DRW lmslip ETH DEE. Xmsn/Dif temp, Boost/EGT, Xmsn Filter, MagHytec diff w/synthetic. 9. 5', 91 Sunline camper (Home). GVW 10800. 5800 miles mpg @ 60 mph 15 (& climbing) around town mpg 13-14. Gauge readings @60 mph I 10 Fla, 70 degrees outside temp. Boost-8 , EGT 750, Xmsn-175, Diff-145. (Diff runs 25-40 degrees cooler than Xmsn depending on outside air temp.
John,
I've had real good luck @ www.eguages.com Don provides way good service and exl. prices... ..... #ad
Colin
2001 Quad,4x4,AT,4. 10LS,LB,Loaded enough,stock,mostly... . 65 Chevelle sedan, Hella nice driver, 53 Nash Rambler Convt,1 of 653 built,[not a Metro], GM drivetrain, injection, and auto/od
Specialized FSR PRO Stumpjumper,Cannondale F2000, Loaded
MTD Lawn tractor with flames Cummins ISB
12' fishin' boat, loaded. .
John:
If you go back into the "Products and
Accessories" Archives there is a good
thread titled "Gauge Pictures Anyone?"
Several members (including myself) had
pictures of their gauges posted on this
thread. I believe it was around 03-09-01.
Take a look at the pictures to see what
you like.
John_P
Red '96 4x4 2500 Auto 3. 54, TST #5, Major Pump Mods(By "Scheid Diesel") 370 Diamond B Injectors, Gov. Spring kit, AFC Spring kit, Banks Exhaust, Prime Loc, Cummins Chrome Kit,Psychotty Air Filter, Pro-Torque Converter, BD Valve Body, BD Pressure Loc, Isspro Gauges, Sendel 16" Alum Wheels w/ 33" BFGs
