What is everybody using with their 3500's to get a better ride quality? I have a 17' and it rides like a damn stagecoach...
Replacing shocks on a new 17 will not measurably improve the ride.Appropriate air pressure for the load will have a greater affect.To make a significant ride quality you must change spring rate and travel,visit Carli suspension to see some options.
Softer spring rates with properly valved shocks will change your vehicle. I have Don Thuren softer rate springs with King 2.5 shocks with Don Thuren valving. All I'm going to say is you don't know what you don't know. I had no idea my truck could ride so unbelievably. Firm in corners, yet I can hit large speedbumps at 50 mph. Very expensive, but worth every penny. Btw, the reason I got them was to control a 4000 lb slide-in truck camper, which it does perfectly.
I disagree. A lower spring rate just means that you need a taller spring to arrive at the needed ride height rate. Without resorting to by-passes a damper can be valved to work in this application w/o being obnoxious. Done all of the time in the stock desert racing classes. I consider the bumps to be part of the usable suspension, not to be used only when the driver runs out of talent.A stock ride height spring would not work.without the extra travel it would bottom out unless you valve the shock too firm to see any benefit
I disagree. A lower spring rate just means that you need a taller spring to arrive at the needed ride height rate. Without resorting to by-passes a damper can be valved to work in this application w/o being obnoxious. Done all of the time in the stock I desert racing classes. I consider the bumps to be part of the usable suspension, not to be used only when the driver runs out of talent.
Thuren used to have a +1" spring for my vintage truck. They weren't popular enough and I was too late to get the last set. He told me that the reason for the +1" wasn't more travel for the suspension (though that was a collateral benefit), it was to get an off the shelf sized King damper to fit properly.
The 2nd's are lighter so maybe that helps.
Have some made and tell me how they work for you......not worth the effort and money
