DannyW,
TV's don't have vacuum tubes anymore either.
True freeplay went out in the early 80's with old mechanical release systems.
For discussion purposes all modern pass car and PU's have the release bearing turning continuously with engine RPM. Engine is turning, bearing is turning.
The bearing also has preload applied to it via a spring inside the slave cylinder pushing on the seal->piston->pushrod->fork->bearing->diaphragm spring tips. The bearing is always on the diaphragm spring tips.
Show and tell time. Clutch installed on engine. Install transmission COMPLETELY. Now take a new slave cyl only (still has the shipping straps holding pushrod retracted) install into trans like normal.
With the above demo install you just established the clutch release bearing preload. The hydraulic system isn't even complete and it's (preload) there.
If the shipping straps are not holding the piston/pushrod back you just have a bit more push distance to get things bolted up. No big deal.
If you report that it was requiring Herculean strength to get nuts started then question is is the master cylinder installed completely including pushrod to pedal and the pedal is slightly pushing the pushrod in a bit? If so, then you were trying to move fluid back into reservoir but the return port was closed cause clutch pedal was down.
The way I test these hydros. First finger tip only assessment of hydro's. Two finger tips push pedal. Observe how far PUSHROD travels before you feel pressure being created. Stock NV5600 hydro's 1/8" stock G56 hydro's can be about 3/16" due to extra clip connections and a doohickey in the system just above the slave cyl.
Now for the money shot on hydro's. Requires steering wheel puller and 5/16" by about 2 1/2-3" long, nuts, washers. Remove slave cylinder. Remove pushrod and dust boot, set aside. NO ONE TOUCHES CLUTCH PEDAL YET. Attach puller to slave cyl flange, centering screw in cyl, snug up bolts, turn screw in to contact piston then turn in another 1/2-3/4" or so.
Support on cyl and puller on underbody of truck.
Now, push clutch pedal with TWO FINGERS (not your foot) and very carefully measure MC pushrod travel distance to starting to create pressure. Observe several times. Seriously measure this cause if you guess or swag might as well not do the test at all. We don't need to use foot to feel air bubble in this system and if you stomp on hydro's, well I guess you find what breaks next.
This master cyl design burns up less than 1/8" piston travel to go from relaxed zero PSI to tappet closed and pressure creation mode. Greater than 1/8" = air in system. If so, let me know and I can walk you how to BURP the system.
Clutch release test.
Engine running, push pedal to floor, give it a 2-3 count, select gear, should click into gear like normal.
Engine running, clutch pedal on floor normal, trans in 1st, no brakes applied, no fueling, slowly lift pedal observing for the moment truck starts to pull and how far in inches pedal came off of the floor to start pulling. Varies a bit but 1 1/2-2" reserve travel is a decent amount. Absolutely should not start pulling as soon as you start to lift pedal or even worse as you release brakes.
Gary
