The Prodigy is adequate but not the most capable controller. I'd suggest looking at the Brakesmart or the Jordan Ultima 2020.Belchos said:I am going to have to wean myself from my 92 pretty soon and put a fifth wheel hitch on the new truck for my stock trailer. I will be looking at controllers. Can I ask why you chose the Tekonsha Prodigy?
You might also reconsider if, as I did, you had an inertial controller fail to engage the trailer brakes because of rain-slicked roads, jack-knife the 5th wheel and almost put the whole rig into a ditch. An inertial controller depends on deceleration generated by the truck to determine how much braking to send the trailer. If the truck doesn't generate enough deceleration because of slick pavement, the trailer (at least with a non-boosted inertial controller such as the Tekonsha Sentinel I had at the time) doesn't get braked. Things go downhill quickly when that happens.JHardwick said:If I was a contract hauler and on the road daily with a load, I may reconsider.
Both the Jordan and Brakesmart connect directly to the truck's braking system; therefore, whatever you do with the truck's brake pedal is converted directly into proportional braking of the trailer. The Jordan accomplishes this with a mechanical (sheathed cable) attachment to the brake pedal arm; the Brakesmart uses a hydraulic pressure transducer to measure brake system pressure.The Sequel said:How do the Jordan and Brakesmart differ form the Prodigy and what is the typical cost difference?
RustyJC said:You might also reconsider if, as I did, you had an inertial controller fail to engage the trailer brakes because of rain-slicked roads, jack-knife the 5th wheel and almost put the whole rig into a ditch. An inertial controller depends on deceleration generated by the truck to determine how much braking to send the trailer. If the truck doesn't generate enough deceleration because of slick pavement, the trailer (at least with a non-boosted inertial controller such as the Tekonsha Sentinel I had at the time) doesn't get braked. Things go downhill quickly when that happens.
Ya pays yore money and ya takes yore choice. It's always amazed me to see an individual buy a $35K truck, a $55K 5th wheel and then select a brake controller based on saving $50-$200 rather than protecting a $90K investment, not to mention one's family and others on the roads!
Rusty
When someone pulls into one's path, any speed is excessive for conditions. It's not a perfect world - one doesn't always have time to be fumbling around reaching for a manual control. If the brake controller works as it should, manually applying trailer brakes should not be required in an emergency stop. By the way, my 1996 Ram 3500 (the truck in which the inertial controller was installed) only had rear wheel ABS - not much help.JHardwick said:I've never had a problem, especially with the ABS. There are a couple things to consider, "speed for condition" comes to mind initially, and there is always an over ride as well.
Sorry you took it that way - I'm as serious as a heart attack about what I said. I'm just offering others the opportunity to learn from my experiences without having to pay tuition at the school of hard knocks. Selection of a brake controller isn't the place to decide to "cheap out". I used a time-based controller before I used an inertial controller (I've been at this for awhile). When I bought the Tekonsha Sentinel, the Brakesmart wasn't even on the market, and I had never heard of a Jordan. If you disagree with my recommendations, you're certainly free to ignore them, right?Your last paragraph sounds sarcastic if not condescending, but by your own admission you used an inertia controller yourself. So why shake your head in disgust because I use one?Guess I'll roll my eyes here too, lol.
You would be wrong if you did. Once initialized for my trailer (previous or this one), I've never touched it since.EEdmondson said:I would think that the Jordan would be hard to keep adjusted.
