Details here: TDR Privileges
I had this happen to me with my 98 truck. When I installed the kickdown cable I inverted the lever which caused this. The other time was because the governor pressure sensor was going bad. Check for codes to see if anything shows. If not check you kick down cable for play. When you push the accelerator pedal such as with your hand, watch underneath and make sure you kick down lever moves as well. Any play could cause a problem.
