jwduke said:
Is the wire for a fuel heater? Looks like a nice setup!
The wires are for the heater. There's another 1/2" port on the bottom for the WIF sensor, but I didn't get that option.
I still need to find a place to mount it. I haven't opened the hood yet to see if it would fit where Ryan mounted his filter (driver's side of block next to intake manifold pipe). Even though the assembly is 11" tall, I still need about 4" more clearance below it so that I can unscrew the filter and have it clear the mounting head. It looks like under the hood there is some vertical clearance between the hood and valve cover (for example) and guys do manage to fit twin turbos in there too... so we shall see. The main difference between Ryan's and my truck is that I have some performance boxes with their wiring harnesses taking up some space where Ryan mounted his filter.
In case anyone is interested, I ordered the filter from usdieselparts.com
690R122 fuel filter/water separator $215. 60
RK11861 heater relay kit $142. 61
Shipping $ 11. 79
TOTAL $370. 00
Tax = $0 from Montana
Deciphering the Racor part #:
690R = non-primable filter head at 90 gph (490R = primable head)
12 = 12 volt heater (200 watts activated <45* and shuts off >75*)
2 = 2 micron
In hindsight, the relay kit is just a heavy duty relay so the electrically inclined could have made one for a lot cheaper (without actually trying it for myself).
Also, the total cost + holley blue pump ($100) + fittings/hose is at most the same price as a FASS, but probably (a lot ??) less with parts one can get from any auto/marine/heavy diesel shop... only drawback will be my time to fit everything together.
This will not be happening soon. It's cold outside and I don't have a garage or shop and I am kind of sick of working on my truck as of late after all the high pressure fuel system issues I've finally resolved. However, once completed I'll be sure to post a write-up and, who knows, maybe someone else will read this and get some ideas and save me tons of time (hint. . hint... hint!)
