First, the limits are 112,000 bytes - not 12,000. For instructions on how to resize pictures, upload pictures to the forums or to your readers rigs, and how to put pictures from your readers rigs section in posts look in the TDR Website/roundtable FAQ forum -
https://www.turbodieselregister.com/forums/forumdisplay.php?f=152 . I do need to update the upload to the forum instructions but if you look at it you should be able to get through it even though the pictures aren't accurate. There are good reasons to have the limit set where it is. A 112,000 byte limit will let you upload 1024x768 images - which is an entire screenful (or more) for probably 90% of the users out there. Take this picture for example - it's 97,013 bytes and is a 1024x768 photo (click on the photo for a full size picture):
We have many dial up users that use the system. A single 112,000 byte picture takes approximately 32 seconds to load on a 28k connection. A single 640k picture would take approximately 3 minutes 7 seconds to load on that 28k connection. Now imagine if you had several pictures that size on a post. In addition in order to have the forums display properly the image has to be resized to fit on the screen - the system resizes them to 560 x whatever for display. If a picture is displayed wider than what can fit on your screen then all of the text on that page will word wrap at that width and you would have to scroll left and right to read all of the text on that page.
The issue that you are having tdecosta is that your images as they are coming out of your camera are uncompressed. If you change the compression on those images to 50% (JPG) you will find that you have no noticable difference in the picture quality at all and will have a HUGE difference in the file size. That picture above at 50% compression is 97,013 bytes at 50% compression, at no compression it's 491,480 bytes. Here is that same picture uncompressed -
. Compare the two and I doubt you'll notice any difference at all although the file size is 506% smaller. That picture uncompressed would take approximately 2 minutes 20 seconds to download on that 28k dial up connection. We take speed issues of the users very seriously here and try to do everything we can to keep speed up while providing as many services as possible. Hopefully this helps to explain further the reasoning that the limits are set where they are - please feel free to ask any questions.
-Steve St. Laurent
Webmaster
P. S. I'm moving this to the website forum.
