Here is honest mileage for a 96 5 speed with 172K on it. Averaged over the last year, 53 fillups. 19. 2 mpg for all types of driving. Only towed once in May, if you remove these the 'average' increases to 19. 3 mpg. This is running unloaded, a dually with Michellin XPS, 225/75-16 (shorter than stock so the final drive rollout - ratio is slightly shorter (3. 69 versus stock 3. 55) - means higher engine rpm. I've corrected the speedometer drive gear for the shorter tires I typically drive 70 - motor turns 2250. If I could ever drive at 2000 rpm, this truck would average in the low 20's, probably 21. 8-22. 8. But 27 mpg? I'm told that bumping the timing helps but 5 mpg! I guess I need to find that US Gear 2 speed splitter if by dropping my RPM from 2250 to 1850 will get me 27 mpg. I could pay for the splitter in no time with the price of diesel fuel on that increase. ROI would still be 4 years but look at the reduced load on the engine!
I have to keep records in that my fuel module is messed up. It's easier to do this than pony up several hundred dollars for a new module.
Engine is stock except for an AFE air filter, the cat replaced with a 3. 5 inch pipe, and an early Banks cat back exhaust that I bought used from the TDR - no performance mods to the 215 / 440 engine or fuel pump. Original timing (12. 5), original injectors, etc.
I do have Alcoa's which seem to run truer (less vibration) than the stock steel rims.
DateVehicle MileageTrip MileageAmountfuel qty $/gal MPG
03/12/03 144588 531 $50. 00 29. 959 1. 669 17. 7
03/26/03 145062 474. 5 $40. 01 25. 500 1. 569 18. 6
04/30/03 145595 532. 5 $40. 00 29. 876 1. 339 17. 8
6/1/2003 146084 489. 1 $38. 00 27. 550 1. 379 17. 8
7/12/2003 146561 477. 5 $38. 65 28. 440 1. 359 16. 8
8/23/2003 147058 496. 2 $37. 00 26. 831 1. 379 18. 5
10/11/2003 147555 497. 3 $37. 01 27. 638 1. 339 18. 0
10/28/2003 148095 540. 5 $38. 00 27. 959 1. 359 19. 3
12/31/2003 148509 414 $29. 00 21. 340 1. 359 19. 4
1/11/2004 148980 470. 2 $40. 00 27. 414 1. 459 17. 2
1/16/2004 149461 481. 5 $34. 50 22. 273 1. 549 21. 6
1/19/2004 149961 500. 5 $38. 00 25. 347 1. 499 19. 7
1/21/2004 150459 497. 4 $40. 00 25. 821 1. 499 19. 3
1/27/2004 150902 442. 8 $34. 00 21. 948 1. 549 20. 2
2/1/2004 151383 481. 2 $36. 00 24. 017 1. 499 20. 0
2/26/2004 151800 417. 7 $30. 00 20. 010 1. 499 20. 9
3/17/2004 152262 461. 3 $37. 00 24. 039 1. 539 19. 2
4/5/2004 152748 486. 4 $36. 00 23. 091 1. 559 21. 1
4/15/2004 153244 496. 2 $35. 00 22. 305 1. 569 22. 2
5/1/2004 154189 437. 2 $34. 00 21. 806 1. 559 20. 0
5/1/2004 154568 378. 3 $42. 00 25. 010 1. 679 15. 1
5/1/2004 154975 407. 4 $40. 00 23. 964 1. 669 17. 0
5/4/2004 155428 453. 3 $43. 00 28. 686 1. 499 15. 8
6/16/2004 155944 515. 5 $44. 50 26. 340 1. 689 19. 6
6/24/2004 156396 452. 4 $37. 00 22. 574 1. 639 20. 0
6/29/2004 156896 500 $41. 25 26. 122 1. 579 19. 1
7/7/2004 157404 507. 9 $40. 00 25. 991 1. 539 19. 5
7/16/2004 157947 542. 6 $41. 00 25. 964 1. 579 20. 9
7/27/2004 158466 519. 8 $43. 00 27. 058 1. 589 19. 2
8/4/2004 158983 517 $42. 25 25. 315 1. 669 20. 4
8/11/2004 159493 509. 6 $47. 00 28. 161 1. 669 18. 1
8/23/2004 160036 543. 8 $47. 50 28. 123 1. 689 19. 3
8/30/2004 160544 507. 9 $46. 75 26. 882 1. 739 18. 9
9/5/2004 160949 404. 6 $35. 50 20. 413 1. 739 19. 8
9/14/2004 161444 494. 7 $42. 75 24. 440 1. 749 20. 2
9/24/2004 161934 490. 7 $48. 25 25. 542 1. 889 19. 2
10/1/2004 162461 526. 7 $48. 00 25. 278 1. 899 20. 8
10/13/2004 162988 527 $50. 00 25. 013 1. 999 21. 1
10/19/2004 163527 539 $63. 01 30. 902 2. 039 17. 4
10/25/2004 164046 519 $60. 25 29. 261 2. 059 17. 7
11/11/2004 164539 488. 6 $50. 00 24. 765 2. 019 19. 7
11/13/2004 165038 498. 7 $54. 33 27. 734 1. 959 18. 0
11/24/2004 165551 513 $53. 50 26. 763 1. 999 19. 2
12/2/2004 166044 492. 7 $52. 60 26. 988 1. 949 18. 3
12/8/2004 166480 435. 8 $42. 25 21. 568 1. 959 20. 2
12/22/2004 166974 494. 3 $49. 00 26. 218 1. 869 18. 9
1/3/2005 167496 522. 5 $54. 25 29. 499 1. 839 17. 7
1/14/2005 168478 449. 5 $42. 00 22. 115 1. 899 20. 3
1/19/2005 169005 526. 8 $52. 00 28. 585 1. 819 18. 4
2/1/2005 169479 474. 1 $45. 00 24. 205 1. 859 19. 6
2/8/2005 169985 506. 2 $47. 00 25. 836 1. 819 19. 6
2/14/2005 170523 537. 9 $51. 75 27. 836 1. 859 19. 3
2/21/2005 171022 499. 2 $45. 00 24. 482 1. 839 20. 4
3/3/2005 171539 516. 5 $50. 00 25. 266 1. 979 20. 4
24923 25422. 3 $2,238. 86 1336. 315 1. 673 19. 2
