About to install Geno's banjo bolt for fuel pressure gauge and was wondering why cant I just hook appropriate hose fitting directly to schrader valve?
Originally posted by Briar Hopper
You can, and I did.The needle valve inside is removable, allowing a hydraulic hose type fitting, commonly referred to as a JIC stem, to fit on there. While I have them in stock, there is not much call for them, a lot of people at that point of installing a permanent fp gauge, are also upgrading their fuel lines to larger ones, so the stock schraeder or banjos get set aside.
There are many different ways to tie into the fuel system... with several different types of fittings. The search feature on this site works really great, try it.
