I had to remove my drivers side side step/running board. The way that Dodge thought would be a good way to go is not for "Work" trucks. Lasted 9 months.
Evidently my using the boards to scrape, and knock the mud/snow off my boots before I got in the cab was too much for the mounts. I weigh a whopping 165 and it still managed to rip the lower two threaded inserts out of the sheet metal.
I'll try to post some pics if I can find a place not covered in water/snow.
Anyone know if there is any frame mounted kits out there?
I was leery of using the rocker panel mounts, but I'm not an engineer. I guess I was right - even the passenger side, who only had the occasional passenger simply step on them are tearing out. My first clue was the amount of movement they had on the first use when I stepped on them.
