Pourinthecoal said:Gunz: that gap that is the result of removing the SR has the abiity to restrict flow, however that is in the instance of the air being PUSHED into the turbo (which by all acounts does not happen, no matter what the "Ram Air" manufacturers what us to think). This gap is like a wall against the aerodynamics, think the tailgate of your pickup. In effect, the air is not pushed into the turbo unless we are going REALLY fast and the turbo has no spool, however when we are using the turbo (making it sing so to speak, producing power) it is PULLING air into itself, a volume smaller than the intake tube, therefore the wall does'nt have an significant effects on the air entering the turbo. Heck, I'm almost convinced that even if the air was pushed into the turbo it would have minimal effects, as the trapped air in that "wall" or "gap" created would simply BE trapped and make an aerodynamic "ramp" int the cylinder by the trapped air.
Keep in mind, this is all in theory of what I've learned in my university physics class (about 5 years ago), so I have no physical readings or evidence to back it up. So if anyone else here an either support this theory or disprove, you're more than welcome! The real world results always put theory back in its place in the end...
I see what you're getting at but the air doesn't have to be pushed through mouth of the turbo by a ram effect for there to be a movement of air through the intake tube. Bernoulli's Principle applies to air acting on a convergent/divergent duct regardless of whether the air column is moving due to pressure or vacuum. My initial impression is that the cavity created by removal of the ring is just a hollow space. A space that is exposed to the moving air column, and a space that is not uniform in shape. If isolating that space from the moving air was their goal, I find it odd that they'd choose an apparent convergent duct design.
